jasmtnljj
#1 Posted : Thursday, April 19, 2012 4:46:55 PM(UTC)
jasmtnljj
The fan turns on, everything hums and makes noises but it won't cool down at all even on the highest/coldest setting. When I first turn it on I hear the sound like air leaking/hissing but it goes away within 5 minutes and sounds normal. BUT, it still doesn't cool. I tried taking some photos of the compressor as it was running and I saw some "smoke" or I thought... maybe its freon? I could only see it when the red would come on my camera but not when it would flash. It was hard to see actually but my camera was recently fixed so I don't think its the camera smoking. Nothing smellsl ike smoke. It makes me think it is escaping freon but i dont know.
The warmth was sudden.. it had been working fine. Leaking freon i think would be a gradual thing. It had been running for at least 18 out of the previous 24 months. It is possible that the circuit the fridge was on had some issues. Within a week of the freezer not working i did have to flip the breaker but never found the cause of it being tripped. Maybe connected... maybe not
Simon / APP Team
#2 Posted : Thursday, April 19, 2012 5:06:43 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Remove the rear cover inside the freezer and observe the evaporator coils.
Do you see any frost pattern. Just in one corner, top or bottom?
Is the fan running?
Please post the results.
Simon.
jasmtnljj
#3 Posted : Friday, April 20, 2012 4:18:28 AM(UTC)
jasmtnljj
Fan does run..... but no, nothing forms on the inside at all. It actually feels a tad warmer inside the freezer after I run it for a half hour than air temp of the room.
Simon / APP Team
#4 Posted : Friday, April 20, 2012 7:54:23 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
There is the problem with sealed system.Check the warranty. Normally it's more than 3 years.
The repair could be very costly and require skills and equipment.
Thank you.
Simon.
jasmtnljj
#5 Posted : Friday, April 20, 2012 11:32:04 AM(UTC)
jasmtnljj
I will see if I can find my receipt for it. Or can Frigidaire know it is within the 3 years due to manufactor date? TIme to go find some info! thanks
