Barbara Taylor
#1 Posted : Monday, March 23, 2009 8:39:14 AM(UTC)
Barbara Taylor
Can you tell me how to remove the top front panel from our Kenmore dryer so that I can replace the starter switch? We've done all we know to do and it's still not budging!
Thank you!
#2 Posted : Tuesday, March 24, 2009 12:52:16 PM(UTC)
Barbara,
What is the original problem with the dryer?
Barbara Taylor
#3 Posted : Wednesday, March 25, 2009 10:38:56 AM(UTC)
Barbara Taylor
We are replacing the starter switch. (Have the switch... just need to get to the old one).
Thanks!
#4 Posted : Wednesday, March 25, 2009 1:59:57 PM(UTC)
Remove the screw from each side of the console. Pull the console forward and up to remove the tabs on the bottom of the end caps, out of the holes in the top. Lift the console up and lay it on its back.
P.S. If the dryer stops as soon as you release the start button then the problem is a bad control board and not the start switch.
jmd_forest
#5 Posted : Wednesday, March 25, 2009 2:12:20 PM(UTC)
jmd_forest
Just did it this morning with a Kenmore 70 series. Assuming the 70 Series is constructed similarly to your machine:
Pull out the lint trap from the top of the console and remove the 2 screws. Pop the top cover up at each front corner using a screwdriver between the top cover and the body and gently pry up each corner until free. The top should now tilt backwards. At each front corner, about 2 inches from the top is a screw. Remove the screw from each front corner. Lift up a front corner of the washer and put your shoe underneath being careful to NOT catch your toes. Give the side panel, by the front where you have lifted it up by your toe, a good pop down with the palm of your hand and that front corner should separate from the side panel. Repeat at other front corner.
jmd_forest
Maytag MED7500YW 1 Front Panel Removal? (Dryer Repair)
by Senator 5/18/2015 4:58:46 PM(UTC)
GE Dryer front panel removal (Dryer Repair)
by Hyperventilate 11/5/2013 8:28:03 PM(UTC)
Full Front Panel Removal (Dryer Repair)
by Inquirer 2/19/2013 1:50:02 PM(UTC)
Front Panel Removal? (Dishwasher Repair)
by jim@vacuumtubesinc.com 8/8/2012 7:33:16 PM(UTC)
LG Dryer front panel removal (Dryer Repair)
by gusnich 4/13/2012 11:16:05 AM(UTC)
Front panel removal (Washer Repair)
by Dean2L2@AOL.com 10/14/2011 12:28:37 PM(UTC)
Front Panel Removal (Dishwasher Repair)
by Edward Wieczorek 7/30/2011 6:40:42 AM(UTC)
GE front panel removal (Washer Repair)
by blevdog 5/18/2011 9:45:16 AM(UTC)
by bobets2@tds.net 11/17/2010 12:13:48 PM(UTC)
by bobets2@tds.net 11/17/2010 12:05:35 PM(UTC)
by skullz 9/12/2009 7:54:07 AM(UTC)
washer front panel removal (Washer Repair)
by zamboy 5/5/2009 3:47:30 PM(UTC)
by DREW255 10/1/2008 1:34:03 PM(UTC)
Maytag Dryer front panel removal (Dryer Repair)
by jkbatt 8/23/2007 5:49:51 AM(UTC)
