jimbmor
#1 Posted : Tuesday, April 17, 2012 10:06:55 AM(UTC)
jimbmor
Opened dishwasher after wash cycle. Soap dispenser open, but soap not dissolved. Dishes not clean. Noted kitchen faucet barely working. Apparently a slug of soft sludge got in water line. Flushed water lines at sink. Removed copper tubing at inlet to dishwasher (DW) and found sludge at inlet filter going to I believe the solenoid valve.
Cleaned inlet filter. Replaced copper tubing with SS flex house. Flushed flex before hooking up to DW - solid stream of water with good pressure. Hooked up to DW and tried to run. No water going in to DW.
Wondering if I should replace solenoid inlet valve? Or is there something else I should try?
Thanks, Jim
Simon / APP Team
#2 Posted : Tuesday, April 17, 2012 11:04:49 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Before replacing the water valve check the float and the switch.
The water inlet valve Part number: 425458
Part number: 425458
Thank you.
Simon.
jimbmor
#3 Posted : Tuesday, April 17, 2012 11:10:22 AM(UTC)
jimbmor
Thanks Simon, how would I access the float?
Simon / APP Team
#4 Posted : Tuesday, April 17, 2012 3:03:49 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Pull out the dishwasher half way. Access on the left.
Thank you.
Simon.
jimbmor
#5 Posted : Tuesday, April 17, 2012 3:23:57 PM(UTC)
jimbmor
Thanks Simon. On this model it turned out I had to take whole left side off, but was simple to do. Float looks fine unless micro switch is bad, but that seems unlikely, and no evidence there has ever been water where that float is. I'll go ahead and order the solenoid valve and see how it goes.
Thanks again, Jim
Simon / APP Team
#6 Posted : Tuesday, April 17, 2012 3:43:35 PM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 5/25/2021 5:32:22 PM(UTC)
KitchenAid KUDS30IXBLA Dishwasher Not Filling Up With Enough Water (Dishwasher Repair)
by navagator 2/6/2021 3:49:58 PM(UTC)
dishwasher not filling mdb5600awb (Dishwasher Repair)
by sac65849 1/4/2021 8:56:23 PM(UTC)
GE Dishwasher not filling with water (Dishwasher Repair)
by shawnkocher508 10/31/2016 12:12:32 PM(UTC)
GE Cafe Dishwasher not filling (Dishwasher Repair)
by Moai Mat 9/6/2015 5:08:45 PM(UTC)
KitchenAid Dishwasher not filling with water (Dishwasher Repair)
by njallison@juno.com 7/16/2015 5:58:31 PM(UTC)
Kenmore Dishwasher not filling up with water (Dishwasher Repair)
by Bukwas 4/25/2014 10:20:04 AM(UTC)
Bosch dishwasher not filling (Dishwasher Repair)
by kywingnut 11/15/2013 7:44:47 AM(UTC)
Maytag Dishwasher not filling with water (Dishwasher Repair)
by icemanbryan 8/15/2013 5:43:03 PM(UTC)
by rcb 12/10/2012 2:57:55 PM(UTC)
GE Dishwasher not filling on wash cycle (Dishwasher Repair)
by JEB735 4/22/2012 11:41:02 AM(UTC)
dishwasher not filling with water (Dishwasher Repair)
by swadmiral 12/3/2011 7:09:04 AM(UTC)
dishwasher not filling up at all (Dishwasher Repair)
by Bill LeVey 8/18/2011 11:46:22 PM(UTC)
by drs2578 4/19/2011 5:22:56 PM(UTC)
