regina.martin
#1 Posted : Sunday, March 22, 2009 9:33:05 AM(UTC)
regina.martin
our fridge is leaking water from underneath every few days. We have not found anything wrong, except there is ice on the bottom and back of the freezer ( bottom freezer fridge without and ice maker ), we are assuming it is related. What and where do we look at?
Thank you very much for your help!
Drags1998
#2 Posted : Sunday, March 22, 2009 11:26:13 AM(UTC)
Drags1998
The DEFROST DRAIN is plugged!!! If you remove the rear wall INSIDE of the freezer you will find The evaporator coil. Under the coil is a drain tray, I think you will find it FULL of ICE!!! If you MELT the ice out of the tray,you will find a 1/2" hole in the tray, what you need to do is: Melt ALL the ICE!!! Even under the metal tray!!!! There will be a hole under the tray that water goes through and runs into the pan under the unit. Take a TURKEY BASTER and fill it with HOT water and FORCE it down the hole until water runs freely down the hole!!! Put it back together,YOUR DONE!!!:)
Whirpool fridge leaking water inside (Refrigerator & Freezer Repair)
by Jules28412 3/28/2015 6:52:47 AM(UTC)
Kenmore fridge leaking water and ice buildup (Refrigerator & Freezer Repair)
by Perplexed1967 5/23/2009 9:10:48 AM(UTC)
