scottpk
#1 Posted : Monday, April 16, 2012 7:25:49 PM(UTC)
scottpk
I'm looking to test the motor on our washing machine - it stopped working last night. I found the testing/replacing motor drive for this unit on your site. I went to do the continuity test but the colored leads on my unit don't match exactly what you have indicated. The motor I have has the following: black, blue, white-violet, white-orange, white-black and yellow.
Can I assume that in my case the violet in your instructions would be the white-violet and the white in your instructions would be the white-orange?
ApplianceJunk
#2 Posted : Monday, April 16, 2012 7:55:56 PM(UTC)
ApplianceJunk
Here is the service manual for the direct drive washer. It's the type of washer you have. Check it out and see if it helps.
http://appliancejunk.com...downloads;sa=view;down=4
scottpk
#3 Posted : Monday, April 16, 2012 10:49:47 PM(UTC)
scottpk
Thanks for the info. I was able to rule out the motor being faulty.:) Seems to be just the coupler that went bad.
Whirlpool PUMP MOTOR TESTING (Washer Repair)
by Joe_cole14 8/24/2012 6:25:06 AM(UTC)
Motor Testing (Washer Repair)
by squier3 2/25/2010 9:20:35 AM(UTC)
Whirpool Motor Testing (Washer Repair)
by ALEJANDRO GONZALEZ 1/15/2009 4:22:13 PM(UTC)
