bp39ash
#1 Posted : Monday, April 16, 2012 7:27:19 AM(UTC)
bp39ash
:D Our water dispenser has always been sooo slow but is now down to a drip. Our ice maker has quit. We used your great blog for troubleshooting & found that our emitter/sensor is working properly (we thought that was the culprit). We changed the water filter & got some ice for about 4 days..now nothing. Water is not flowing into the ice maker reservoir & the water on the door takes 5 min to fill a 6oz cup. Can we access the water line to both & run something through it to check for blockage? Any other ideas on what the problem might be??
#2 Posted : Monday, April 16, 2012 6:17:43 PM(UTC)
Did you dispense 2-3 gallons of water after you replaced the water filter?
Did you check the water pressure from the incoming water line?
bp39ash
#3 Posted : Tuesday, April 17, 2012 5:20:16 AM(UTC)
bp39ash
Hi Gene,
We would probably have to stand in front of the water dispenser for about 4 hrs to get 2-3 gals. When the activator os pushed in by the cup, it spurts a quick stream and then slows to a drip thereafter. Yes, we have checked the water pressure & for kinks in the tubing..both are fine. The water dispenser issue has been a problem for quite a while, but the no ice issue is new. Can we somehow run something through the tubing to check for blockage? As I said earlier, the emitter/sensor seems to be working, but no water is flowing into the ice maker reservoir. We have already replaced the ice maker once with a Whirlpool repair person ($500.00 cost) since we've owned it (2005) and decided to see if we can troubleshoot this 1st ourselves after reading your blog, since that cost is quite prohibitive. Any ideas??
Thanks for responding!!!
#4 Posted : Tuesday, April 17, 2012 1:58:02 PM(UTC)
It is very unusual for both water inlet valve solenoids to fail together. That's why I need you to do the following test.
Turn off the water shut off valve for the refrigerator. Disconnect the water tube from the water inlet valve. Put this tube into a large bucket and open the water shut off valve to check the pressure.
Also check the water feeding tube into the ice maker for icicles inside.
