trail
#1 Posted : 16 years ago
trail
The fridge was working fine and then the light went out, the ice dispenser stopped working, it stopped making ice, the fridge got warm and the freezer is not as cold as it should be. It is empty now and I tried unplugging it, letting it sit and then plugging it back in. The freezer started to get cold but nothing else worked. I believe it might be electrical but am not very savy about refrigerator repairs.
#2 Posted : 16 years ago
What is running, freezer fan, condensing fan. Pull the back off the refrigerator and check to see if the compressor is running or just hot.
#3 Posted : 16 years ago
trail
#4 Posted : 16 years ago
trail
Evaporator fan is running, freezer fan is not, compressor gets hot, freezer still gets cold
#5 Posted : 16 years ago
You will need a volt meter to check things. Seems like you have lost voltage to the freezaer fan motor. If no meter, you can remove the freezer back panel and check for a loose wire, or you can check the door switch, sometimes they go bad, but not too often.
#6 Posted : 16 years ago
As richappy said a meter will make this much easier.SEE BELOW.
By freezer fan I assume you mean the compressor/condenser fan.
Check for 115 volts AC at the fan's connector.
If it is there the fan is shot.
You did not say which light went out.
The light going out may just be a coincidence, check the bulb for continuity as the circuits for the fan and the light seem separate.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
