asheridan
#1 Posted : Friday, March 20, 2009 8:04:59 AM(UTC)
asheridan
I have a side by side amana refrigerator with through door dispensing. I purchased and installed a replacement ice maker from your company part #AP178365 in January. Now I"ve had water on the floor but none getting into the ice maker. The ice maker appears to be going through it cycle and now I don't get any water leak on the floor.
Do I have a bad replacement or is there something else that went bad?
woodchuckie
#2 Posted : Friday, March 20, 2009 8:41:16 AM(UTC)
woodchuckie
Is your problem- water getting on the floor of the kitchen with water leaking out of the water line on the back of the freezer.
Is your problem- water getting on the floor of the kitchen with water leaking out the door of the freezer.
asheridan
#3 Posted : Friday, March 20, 2009 8:48:47 AM(UTC)
asheridan
I don't know for sure there is no water leaking at all right now. I suspect it may have come from the back.
woodchuckie
#4 Posted : Friday, March 20, 2009 9:02:20 AM(UTC)
woodchuckie
But there is not water going to the ice maker??
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear
asheridan
#5 Posted : Monday, March 23, 2009 1:13:18 PM(UTC)
asheridan
When I switched wires on the water valve and hit the water dispenser no water came out at the ice maker, but a couple minutes later water came out the water dispenser. I think the water valve to the ice maker isn't working and the water valve may be bad. Does that make sense? How can this be checked? Thanks
woodchuckie
#6 Posted : Monday, March 23, 2009 1:44:10 PM(UTC)
woodchuckie
Were the wires still swapped when the water came out of the dispenser. If so it shows the ice maker is calling for water. You have already checked the valve and the ice maker side of it is bad. You can now replace it.
No water in ice maker (Refrigerator & Freezer Repair)
by bbeckley 5/22/2012 10:10:29 AM(UTC)
need help - no water in ice maker (Refrigerator & Freezer Repair)
by TRC 8/6/2008 4:34:00 AM(UTC)
