My dishwasher is running too long on all cycles. I have to time it, stop it and do a quick rinse to finish. Can you help figure out the problem?
See the attachment for the tech sheet. Could be a problem with the heater circuit. The unit is trying to reach a set point temperature and for some reason cannot so it hangs. If it has a cycle with no water heating try that to see if it runs OK. Does it dry the dishes at the end of the cycle. If not then I would check the heater resistance (10 to 35 ohms) and the hi-limit thermostat resistance (0 ohms at room temperature). Check the thermistor resistance. Check the incoming water temperature, should be at least 120 degrees F. Try running the diagnostics. |
THIS FORUM IS DEAD!!!!!!! |
