nursebjm2
#1 Posted : Monday, April 9, 2012 4:15:10 PM(UTC)
nursebjm2
My dishwasher is running too long on all cycles. I have to time it, stop it and do a quick rinse to finish. Can you help figure out the problem?
#2 Posted : Wednesday, April 11, 2012 3:27:30 AM(UTC)
Could be a problem with the heater circuit.
The unit is trying to reach a set point temperature and for some reason cannot so it hangs.
If it has a cycle with no water heating try that to see if it runs OK.
Does it dry the dishes at the end of the cycle. If not then I would check the heater resistance (10 to 35 ohms) and the hi-limit thermostat resistance (0 ohms at room temperature).
Check the thermistor resistance.
Check the incoming water temperature, should be at least 120 degrees F.
Try running the diagnostics.
File Attachment(s):
16519200.pdf (1,110kb) downloaded 9 time(s).
