buckeye2b
#1 Posted : Thursday, March 19, 2009 7:24:36 AM(UTC)
buckeye2b
My icemaker started to not stop making ice:( ...... it continued to make ice even when the feeler arm was in the stop position:confused: . I took the mounting plate off to see if I could see what the problem was. I couldn't find anything visably wrong so I put the mounting plate back. Now.... no water goes to the icemaker but the icemaker still continues to run without any water going to it:mad: . If I pour water into the tray, it will freeze the water and dispense the cubes into the ice bucket. Can you tell me how to fix this problem and what parts I'll need to replace with new parts.:) Water does still come out of the water dispenser on the refrigerator/freezer door.
woodchuckie
#2 Posted : Thursday, March 19, 2009 10:49:14 AM(UTC)
woodchuckie
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
buckeye2b
#3 Posted : Thursday, March 19, 2009 2:33:14 PM(UTC)
buckeye2b
I did swap the wires on the dual water inlet valve. Now the water despenser does not work until the icemaker cycles and drops the cubes... then it despenses about 3/4 cup of water without pushing the despense pad. But there is no water going to the icemaker even when I push the despense pad on the water despenser. The ice maker still cycles even though there is no water (ice) in the icemaker. Can you help fix this problem? What or any new parts needed?
THANKS A BUNCH!!!
woodchuckie
#4 Posted : Thursday, March 19, 2009 4:24:57 PM(UTC)
woodchuckie
The one side of your water inlet valve is not working. It might just be stuck and playing around with it might fix it or just replace the entire water inlet valve.
buckeye2b
#5 Posted : Thursday, March 19, 2009 4:47:40 PM(UTC)
buckeye2b
I can replace the water inlet valve no problem... THANKS! But what about the icemaker continually making ice and not stopping, even when the feeler arm is in the stop position? What would cause that to happen? Is there a part to replace to correct that problem?
woodchuckie
#6 Posted : Thursday, March 19, 2009 8:57:05 PM(UTC)
woodchuckie
There is a switch the arm has to "make" to stop the process. Take the plastic end cover off the ice maker and look for what moves when the arm is lifted up and down. I have had to slightly bend parts so the switch would be contacted.
buckeye2b
#7 Posted : Wednesday, March 25, 2009 11:07:41 AM(UTC)
buckeye2b
woodchuckie,
A big thank you! I ordered a new water inlet valve and a new switch from AppliancePartsPros.com Friday, I received the parts Tuesday and 1/2 hour later my icemaker was working just fine. THANKS AGAIN!!!
Samsung Icemaker Not working - French door (Refrigerator & Freezer Repair)
by mham99@gmail.com 2/2/2020 7:30:26 AM(UTC)
LG LFX25960ST icemaker not working (Refrigerator & Freezer Repair)
by dlehnhardt 6/21/2019 1:24:06 PM(UTC)
Icemaker not working (Refrigerator & Freezer Repair)
by jakiche 5/7/2015 6:19:40 PM(UTC)
KSCS25FTMS - Kitchenaid Fridge Lights/IceMaker Not Working - But Fridge/Freezer Work (Refrigerator & Freezer Repair)
by cgsauer 4/7/2015 5:25:13 AM(UTC)
Kenmore Icemaker not working (Refrigerator & Freezer Repair)
by belize2020 6/7/2013 3:27:07 PM(UTC)
Kitchenaid icemaker not working (Refrigerator & Freezer Repair)
by gmpfeffer 2/24/2013 1:42:19 PM(UTC)
GE Side by side icemaker not working (Refrigerator & Freezer Repair)
by Aleste 1/31/2013 3:51:41 AM(UTC)
2nd New Icemaker not working (Refrigerator & Freezer Repair)
by RonBuice 1/16/2013 4:14:41 AM(UTC)
GE Refridgerator Freezer and Icemaker Not Working (Refrigerator & Freezer Repair)
by redspider 12/17/2012 2:17:36 PM(UTC)
Kitchenaid Icemaker not working (Refrigerator & Freezer Repair)
by Stekelenburg 12/12/2012 9:55:44 AM(UTC)
LG icemaker not working (Refrigerator & Freezer Repair)
by AKFatBoy 9/26/2012 9:12:24 AM(UTC)
Maytag Side by Side - Dispenser/Icemaker not working after filter change (Refrigerator & Freezer Repair)
by geodon7 9/7/2012 10:00:31 AM(UTC)
Kitchenaid Fridge Icemaker not working (Refrigerator & Freezer Repair)
by lancecowell 7/12/2012 4:04:09 PM(UTC)
by RosemaryCheatwood 6/20/2012 8:55:29 PM(UTC)
LG Icemaker not working efficiently at all (Refrigerator & Freezer Repair)
by dony95 6/15/2012 4:17:52 AM(UTC)
