2 Pages12>
ereichard
#1 Posted : Tuesday, April 3, 2012 9:52:46 AM(UTC)
ereichard
when the unit is plugged in you can hear the comp. and condenser fan on. The digital temp control shows both sides at 70-75. I do not hear the evap fan running and the control shows the freezer setting at 0 and the fridge at 38. I have a multi meter but I'm not sure how to test the control box. Could it be something other then the control and if so where would be a good place to start?
Simon / APP Team
#2 Posted : Tuesday, April 3, 2012 10:58:15 AM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
Open the compressor compartment and make sure that both compressor and condenser motor are running. compressor should be hot to the touch.
Next take the rear panel out in the freezer and look at the evaporator coils. Are they covered with frost?
If the evaporator fan is not running using the multimeter, check for 120v at it's contacts with door switch closed.
Please respond to this post so we can continue with diagnostics.
Thank you.
Simon.
ereichard
#3 Posted : Tuesday, April 3, 2012 1:51:17 PM(UTC)
ereichard
Ok so I checked everything up to the fan and noticed the fan was spinning slowly and iradic. I pulled the fan and hooked it up to 120v and same thing so I think it's safe to say the fan motor is bad
Simon / APP Team
#4 Posted : Tuesday, April 3, 2012 2:43:34 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What about the rest: is the coils getting frosted?
Simon.
ereichard
#5 Posted : Friday, April 6, 2012 9:52:07 AM(UTC)
ereichard
The fridge has been unplugged to keep anything from burning out but when I plugged it in to check the fan the coils did get very cold.
Simon / APP Team
#6 Posted : Friday, April 6, 2012 12:07:49 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Replace the evaporator fan motor Part number: AP4700070
Post the results.
Simon.
ereichard
#7 Posted : Tuesday, April 10, 2012 12:17:21 PM(UTC)
ereichard
Replaced the fan moter and the terminals touched, fan is still good but not working in unit. Is there are fuse or did the control burn out?
Simon / APP Team
#8 Posted : Tuesday, April 10, 2012 1:22:48 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Leave the old evap motor in, reinstall the cover and run the frig for 12 hrs. Put the thermometer inside the freezer, then in to the refrigerator.
Post the results.
Simon.
ereichard
#9 Posted : Wednesday, April 11, 2012 11:23:11 AM(UTC)
ereichard
I dont understand this, what thermometer? the coils are frosting up but the new fan isnt coming on.
Simon / APP Team
#10 Posted : Wednesday, April 11, 2012 12:51:28 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Is the new fan rated at 120VAC?
What is a voltage coming to the motor?
Check it with frosted evaporator.
If you plug the motor directly in the outlet will it work normally?
If you don't get the 120VAC to the motor from the control board - replace the board.
The dual control board Part number: AP3966008
Frigidaire not cooling (Refrigerator & Freezer Repair)
by shel112360 9/23/2015 5:34:06 PM(UTC)
FRIGIDAIRE not cooling enough (Refrigerator & Freezer Repair)
by SHOOTER468 9/22/2014 6:29:18 AM(UTC)
Frigidaire Not Cooling (Refrigerator & Freezer Repair)
by Mr H 4/3/2013 4:28:29 PM(UTC)
Frigidaire not cooling evenly (Refrigerator & Freezer Repair)
by wattsk69 8/27/2012 10:54:54 PM(UTC)
frigidaire not cooling properly (Refrigerator & Freezer Repair)
by colusapaul 5/16/2012 8:25:41 AM(UTC)
frigidaire not cooling (Refrigerator & Freezer Repair)
by kaveman1 2/12/2012 6:29:24 AM(UTC)
Frigidaire not Cooling (Refrigerator & Freezer Repair)
by RHolmes 2/8/2012 1:56:04 PM(UTC)
Frigidaire not cooling well (Refrigerator & Freezer Repair)
by dvjorge 8/19/2011 5:01:24 PM(UTC)
1.5 YEAR OLD frigidaire not cooling anymore!!!!! PLEASE HELP! (Refrigerator & Freezer Repair)
by sssb2000 6/30/2010 3:13:12 PM(UTC)
by Judwyn 3/11/2010 12:32:20 PM(UTC)
2 Pages12>
