The Actuator broke (that's the pad in the water dispenser that you press your glass against to get water) in my double-sided Frigidaire (model: PLHS67EGSB1). I successfully purchased the replacement part, but have no idea on how to replace it. The part came with no instructions on how to do so. I'm not afraid to attempt the replacement, but I'm admittedly an extreme novice in this area.
I don't see where I can remove the front black dispensing area... it doesn't look like it'll fit over the broken actuator. And when I open the freezer door, I don't see where I can access that part of the dispenser without removing the inside of the door. So, before I start tearing my freezer apart, I'm seeking help from anyone who can help to replace this rather small part.
Groups: Expert
It all replaces and accessess from the front. The black cover is attached by plastic clips. Most snap forward and then raise panel towards top of machine in a sliding motion.
Is there a reset switch or button. I replaced water actuator and housing from front and have no power to ice, water or light. Can anyone help?
Originally Posted by: rkwestbury  Is there a reset switch or button. I replaced water actuator and housing from front and have no power to ice, water or light. Can anyone help? What is the complete model number of the refrigerator? Gene.
