M W
#1 Posted : Wednesday, August 18, 2010 8:03:39 AM(UTC)
M W
So I thought my Duet washer was not draining properly. That may turn out to be the case. But here's what I have discovered over the past few days. Washer appears to be completely drained after a load. I spin tub and no sign on water. I left door open and went to work. No loads done or attempted while I was away. I come home and there is a "pool" of water in the back of the machine about two inches deep. I ran spin and drain, all water appears to go away. Try same thing again leaving door open and no wash done. Come home from work and once again there is a pool of water.
Help....please
sidfink43
#2 Posted : Friday, August 20, 2010 6:57:32 AM(UTC)
sidfink43
I think (therefore I am) that some grit has gotten into your water valve and keeps it from shutting completely when it is supposed to be closed.
Replace it,
Part number: AP3128776
and that should fix things.
John kslyly
#3 Posted : Wednesday, April 4, 2012 8:25:31 PM(UTC)
John kslyly
Thank you. I think this reply nailed my problem.
sidfink43
#4 Posted : Thursday, April 5, 2012 3:47:43 AM(UTC)
sidfink43
Great, glad you were able to fix it!
