kdupreez
#1 Posted : 13 years ago
kdupreez
Over the weekend the fridge/freezer started to make a buzzing noise every once so often and it also completely stopped cooling both fridge and freezer:confused:
I think over the past couple of years the fridge was getting noisier when it kicks in..
But the weekend it stopped working.. Every now and again there is a "click".. then a soft "bzzzzzzzz" humming noise for a while, then another "click"..
I'm guessing its the compressor.. everything else works, the water dispenser, etc. works (not cold though)
Any advice?
#2 Posted : 13 years ago
Sounds like the compressor start device has gone bad.
What is the complete model number of the refrigerator?
kdupreez
#3 Posted : 13 years ago
kdupreez
Its a Kenmore fridge/freezer
Model: 596.50392001
Mfg No: P50392000W0
It makes a click, (like a relay engaging) and then a bzzzzzz noise for 10 seconds, then another click.. then silent..
#4 Posted : 13 years ago
The start device Part number: AP4369220
If it would not help, then the compressor itself has to be replaced.
kdupreez
#5 Posted : 13 years ago
kdupreez
Sweet - i bought the part and will give it a whirl when it gets here..
whats the cost of a compressor/motor unit?
#6 Posted : 13 years ago
Originally Posted by: kdupreez Go to Quoted Post
...whats the cost of a compressor/motor unit?...
This is not a DIY job and can cost you $600 - $700. Hopefully the start device will do it.
kdupreez
#7 Posted : 13 years ago
kdupreez
So I think they sent me the wrong part ??
This is what they sent when I ordered the AP4369220 part:
On the LEFT is the original.. (its 2 seperate pieces) and on the RIGHT is new replacement all-in-one piece..
The compressor side will fit just fine (Pic 1), but the wiring harness is completely different on the back? (Pic 2) What do I connect where and how??
UserPostedImage
UserPostedImage
kdupreez
#8 Posted : 13 years ago
kdupreez
i manufactured a wiring harness and connected the part..
same problem... loud "click" then a "bzzzzzzzzz" and then another "click"..
the condenser fan is and always has been running.. and the loud buzz is for sure coming from inside the compressor :(
any chance it might be the capacitor?
i guess this fridge is toast and its time for another one.
#9 Posted : 13 years ago
... the loud buzz is for sure coming from inside the compressor...
It points to the compressor itself. Most likely it's mechanically jammed. The correction is to replace the compressor. Looks like it's time for anew fridge.
You have to call the APP customer service for the return instructions.
