I've just installed a GE dishwasher, which was given to me. When the drain valve is activated the housing pump starts to leak at the shaft for the pump drain valve. Can you advise me on whether replacing the Seal for the pump drain valve shaft will fix this problem or i need to replace the housing pump, should i call a repair guy or just buy a new dishwasher?? I don't know what to do?
Thanks in advanve, Coxay
Here are your parts Replacement parts for GE GSD4330Y73WW | AppliancePartsPros.comTake a look in the "Motor-pump" section Get a seal 417 and a push-on nut 415 You will probably mess the nut up getting it off. If the shaft is not rusted this should fix your problem. Make diagrams of how it goes back together, a digital camera comes in handy here. |
THIS FORUM IS DEAD!!!!!!! |
Does the pump and motor have to be removed to replace the seal or can it be done only on the exterior?
Originally Posted by: denman  Here are your parts Replacement parts for GE GSD4330Y73WW | AppliancePartsPros.comTake a look in the "Motor-pump" section Get a seal 417 and a push-on nut 415 You will probably mess the nut up getting it off. If the shaft is not rusted this should fix your problem. Make diagrams of how it goes back together, a digital camera comes in handy here. This was my issue as well. Great description of the repairs. Quick delivery of the parts. Thanks
