Davy99
#1 Posted : Sunday, April 1, 2012 7:23:12 AM(UTC)
Davy99
The dryer will run but the timer is not working and will run until it is shut of manually. I think the wife put a load in and went to bed so it ran for several hours. When shut off, it was not heating. Im sure the timer is bad but what else has been damaged causing it not to heat?
#2 Posted : Monday, April 2, 2012 2:30:57 AM(UTC)
Replacement parts for Kenmore 11067522600 | AppliancePartsPros.com
If the unit was in an auto cycle switch to a timed dry cycle to see if it now advances.
In timed dry the unit gets power directly from the line.
In auto the timer gets power through the heating coil when the coil is off so if the heater blows the timer will not advance.
So if it does advance in timed dry it could be that just the heating coil is shot. Unplug the unit and one wire at the heating coil and measure it with a meter, should be 8 to 13 ohms.
If it does not advance in timed dry could be that you have a power problem as both the timer motor and heater run off of the 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Here is a post that includes a wiring diagram of this unit
http://forum.appliancepartspros...l?highlight=110.67522600
Davy99
#3 Posted : Tuesday, April 3, 2012 3:24:28 PM(UTC)
Davy99
The unit was in timed dry when we noticed the problem. I tried the auto cycle and still no heat. I flipped the breaker on and off a few times. According to the meter, I have 240 at the plug and 240 on the terminal strip (unit on and off). None of the terminals look bad.
Not sure where to go from here...Thanks
#4 Posted : Wednesday, April 4, 2012 2:20:35 AM(UTC)
Yes it does sound like a timer problem.
Strange that you have no timer advance and no heat in timed dry but could be that the timer has multiple problems.
Set the unit to where it has the problem in timed dry and then shut it off.
Check the TM/WB contacts on the timer.
Check TIMER SWITCH 2 timer contacts R/BK.
If both are open then you have confirmed that it is the timer.
Also with one meter lead on WB and the other on BK you should see approximately 10 ohms (heater). If you then put the WB meter lead to OR you should see 0 ohms. This is with everything connected.
Sounds like you already own a meter but if you were using a voltage checker then I would purchase a multi-meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Guest
#5 Posted : Saturday, January 27, 2024 5:51:04 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Does Kenmore series 500 heating element cycle on and off while drying?
