6 Pages<1234>»
ycontreras
#11 Posted : Tuesday, February 24, 2009 6:16:59 PM(UTC)
ycontreras
Do i order 2 thermistors and the main control board? never mind i found my answer on the other reply you provided.
yolanda
#12 Posted : Tuesday, February 24, 2009 6:50:53 PM(UTC)
Yolanda,
Thank you for such good words.
RemiBlue
#13 Posted : Wednesday, March 4, 2009 12:19:09 PM(UTC)
RemiBlue
I've been reading all the posts and Gene seeme to be the fridge wiz so I was wondering if you could help me. I have the same problem as most everyone here. My freezer is fine but my refrigerater is warm. I have a GE [FONT='Times New Roman','serif']model GTS18KBMCRWW. There was a little bit of frost on the inside back panel of my freezer but I melted it away and the problem is still persisting. When I open the freezer door I can feel cold air coming into the fridge (from the vents inside the top of the fridge) BUT when I close the freezer door I do not feel it anymore. I was thinking the damper control wasn't working but when I looked up my model there wasn't a damper control to replace. Any idea on what might be wrong? I'd hate to have to buy a new fridge if this is an easy fix. [/font]
#14 Posted : Thursday, March 5, 2009 2:12:46 PM(UTC)
Does the fan motor inside the freezer run while the compressor is "on"?
RemiBlue
#15 Posted : Thursday, March 5, 2009 5:16:09 PM(UTC)
RemiBlue
Thanks for the response Gene!
yes - the fan motor is running.
#16 Posted : Thursday, March 5, 2009 8:45:07 PM(UTC)
Remove the rear panel in the freezer and check the drain and all ducts for ice built-up.
Here are the break down diagrams and the parts list for the GE refrigerator Model GTS18KBMCRWW
RemiBlue
#17 Posted : Friday, March 6, 2009 5:19:31 AM(UTC)
RemiBlue
Thanks Gene! I'll let you know how it goes. <fingers crossed>
You truly are a gift!!!!
RemiBlue
#18 Posted : Sunday, March 15, 2009 11:35:36 AM(UTC)
RemiBlue
Hi Gene,
Sorry it took me so long to respond but when I moved out the fridge I noticed that I can't open the back panel. Is it possible that the temperature control could be on the fritz? Do you know if my GE GTS18KBMCRWW has a damper control? I tried to look up all the info on this fridge but I couldn't see a damper control part? Please advise.
In case you forgot (since I took so long to respond) the original problem with my fridge is that the freezer works fine but the fridge is warm (55-60F). I can feel cool air come in with the freezer door open but when I close it I can't feel any cool air in the fridge. I've tried playing with the controls by moving the fridge all the way to 8 or 9 (highest) and the freezer as well but that hasn't been helping so I moved them both back to 6.
Thanks in advance for all your help.
I was just hoping to avoid having to call anyone in so any words of widsom would greatly be appreciated.
woodchuckie
#19 Posted : Sunday, March 15, 2009 2:15:12 PM(UTC)
woodchuckie
Part 301 knob controls the damper wheel part 305. Diagram of fresh food section.
RemiBlue
#20 Posted : Sunday, March 15, 2009 2:43:52 PM(UTC)
RemiBlue
Thanks Woodchuckie! I checked those two parts and they are both working fine. Would you know if that would mean that it's definitely the temperature control I have to replace?
Guest (12)
Freezer works but refrigerator is warm (Refrigerator & Freezer Repair)
by tlelandl 6/21/2009 11:15:17 AM(UTC)
6 Pages<1234>»
