Do i order 2 thermistors and the main control board? never mind i found my answer on the other reply you provided.
yolanda
Yolanda,
Thank you for such good words.
I've been reading all the posts and Gene seeme to be the fridge wiz so I was wondering if you could help me. I have the same problem as most everyone here. My freezer is fine but my refrigerater is warm. I have a GE [FONT='Times New Roman','serif']model GTS18KBMCRWW. There was a little bit of frost on the inside back panel of my freezer but I melted it away and the problem is still persisting. When I open the freezer door I can feel cold air coming into the fridge (from the vents inside the top of the fridge) BUT when I close the freezer door I do not feel it anymore. I was thinking the damper control wasn't working but when I looked up my model there wasn't a damper control to replace. Any idea on what might be wrong? I'd hate to have to buy a new fridge if this is an easy fix. [/font]
Does the fan motor inside the freezer run while the compressor is "on"?
Thanks for the response Gene!
yes - the fan motor is running.
Remove the rear panel in the freezer and check the drain and all ducts for ice built-up. Here are the break down diagrams and the parts list for the GE refrigerator Model GTS18KBMCRWWGene.
Thanks Gene! I'll let you know how it goes. <fingers crossed>
You truly are a gift!!!!
Hi Gene,
Sorry it took me so long to respond but when I moved out the fridge I noticed that I can't open the back panel. Is it possible that the temperature control could be on the fritz? Do you know if my GE GTS18KBMCRWW has a damper control? I tried to look up all the info on this fridge but I couldn't see a damper control part? Please advise.
In case you forgot (since I took so long to respond) the original problem with my fridge is that the freezer works fine but the fridge is warm (55-60F). I can feel cool air come in with the freezer door open but when I close it I can't feel any cool air in the fridge. I've tried playing with the controls by moving the fridge all the way to 8 or 9 (highest) and the freezer as well but that hasn't been helping so I moved them both back to 6.
Thanks in advance for all your help.
I was just hoping to avoid having to call anyone in so any words of widsom would greatly be appreciated.
Part 301 knob controls the damper wheel part 305. Diagram of fresh food section.
Thanks Woodchuckie! I checked those two parts and they are both working fine. Would you know if that would mean that it's definitely the temperature control I have to replace?
