bob&sherry
#1 Posted : Friday, March 13, 2009 8:29:50 AM(UTC)
bob&sherry
washer makes horrible noise when spinning, what is wrong and how to fix? replaced clutch already. can tub bearing be replaced?
ApplianceJunk
#2 Posted : Friday, March 13, 2009 9:29:33 AM(UTC)
ApplianceJunk
Could be something caught in the water pump or the tub bearings going out.
You could check the water pump first to see if something got caught in it.
woodchuckie
#3 Posted : Friday, March 13, 2009 10:28:46 AM(UTC)
woodchuckie
It could also be the clutch assembly shoes worn out resulting in metal to metal rubbing when spinning.
bob&sherry
#4 Posted : Saturday, March 14, 2009 12:26:16 PM(UTC)
bob&sherry
woodchuckie how do I remove agitator coupling?
bob&sherry
#5 Posted : Saturday, March 14, 2009 1:14:02 PM(UTC)
bob&sherry
Originally Posted by: bob&sherry Go to Quoted Post
woodchuckie how do I remove agitator coupling from a G.E. washing machine
