washer makes horrible noise when spinning, what is wrong and how to fix? replaced clutch already. can tub bearing be replaced?
Could be something caught in the water pump or the tub bearings going out. You could check the water pump first to see if something got caught in it.
It could also be the clutch assembly shoes worn out resulting in metal to metal rubbing when spinning.
woodchuckie how do I remove agitator coupling?
Originally Posted by: bob&sherry ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) woodchuckie how do I remove agitator coupling from a G.E. washing machine
