jtowntbo5@yahoo.com
#1 Posted : Monday, March 9, 2009 1:34:26 PM(UTC)
jtowntbo5@yahoo.com
What is the normal temperature for any electric dryer? When should you be concerned with the temperature? Does it vary by brand?
Drags1998
#2 Posted : Monday, March 9, 2009 1:44:49 PM(UTC)
Drags1998
Most new dryers run ABOUT 135-150 degrees at the outlet, some of the older ones ran as hot as 165degrees. This is NO vent hose, NO cloths!!!! If its over these # replace the CYCLING THERMOSTAT!!!!!:)
jtowntbo5@yahoo.com
#3 Posted : Tuesday, March 10, 2009 5:19:12 AM(UTC)
jtowntbo5@yahoo.com
So, if I'm running about a 5 year old amana, and it's at about 180 and cycling down to 130 the cycling thermostat is faulty?
Drags1998
#4 Posted : Tuesday, March 10, 2009 10:51:57 AM(UTC)
Drags1998
If its 180, your very close to having a FIRE!!!!!!!!! If the airflow is good and your sure the vent is clear, then replace the thermostat.:)
jtowntbo5@yahoo.com
#5 Posted : Saturday, March 14, 2009 7:33:41 AM(UTC)
jtowntbo5@yahoo.com
The element for the dryer is at 10 ohms, is that the right amount?
Drags1998
#6 Posted : Saturday, March 14, 2009 11:07:30 AM(UTC)
Drags1998
I believe so. check the cycling thermostat, It should limit the heat to about 150 or less!!!!!
