What is the normal temperature for any electric dryer? When should you be concerned with the temperature? Does it vary by brand?
Most new dryers run ABOUT 135-150 degrees at the outlet, some of the older ones ran as hot as 165degrees. This is NO vent hose, NO cloths!!!! If its over these # replace the CYCLING THERMOSTAT!!!!!:)
So, if I'm running about a 5 year old amana, and it's at about 180 and cycling down to 130 the cycling thermostat is faulty?
If its 180, your very close to having a FIRE!!!!!!!!! If the airflow is good and your sure the vent is clear, then replace the thermostat.:)
The element for the dryer is at 10 ohms, is that the right amount?
I believe so. check the cycling thermostat, It should limit the heat to about 150 or less!!!!!
