Model number 110.85091401 Kenmore Elite Smartheat Quietpak 9. Dryer has power, but will not engage cycle. Instead I get 3 beeps. Ran the error code test (More/Less) and received the SE code on the display and all LED lights were red except Clothes Dry, it was green. Also, Dryer light is not on. I am assuming this is a Sensor Error or Switch Error but I want to ask you, the professional. And if so, how do I replace it? I have the dryer apart and removed the lint screen and the bottom panel so all is exposed.
Groups ready for retrieval: Senior Expert, Administrators Joined: 7/19/2007(UTC) Posts: 27,455
I'm assuming you did find the Tech sheet (behind the toe panel) because you knew how to perform the diagnostic test. Remove the top panel as described on the page 10 to access the door switch and check the door switch for continuity. There are 3 wires connected to the switch: white, brown and blue. Unplug the switch wire harness and check it for continuity at the plug. It should read continuity between the terminals with the white and the brown wires connected to when the door is open, and between the terminals with the white and blue wires connected to when the door is closed. If the readings are incorrect, replace the door switch. - The door switch Part number: AP4588360
OK. I received the door switch part and installed it. Now I receive an error code 88. All lights red except Check Lint Screen. Also, will not engage until I open the door beeps and close the door and press start. At that point it runs with a autotime of 08 min on the LED. Where too next to fix this?
Did you test the door switch prior to order and replace it?
The description on the problem you posted is confusing. There are no "88" error codes listed for this model.
As far as I understood, originally the dryer did not start at all. Now it does start but it does something wrong. Can you describe it more detailed please?
My fault.... I did not press and hold the start button. It is working fine now. Thank you again for all of your help. I guess the 88 code means there are no errors. Thanks again.
You are welcome. I'm glad it's up and running.
