5 Pages<1234>»
rgill
#11 Posted : Monday, March 26, 2012 1:32:48 PM(UTC)
rgill
Well, by the time the weekend has gone by, the temp is back down to 38 degrees. i didn't unplug, but tried not to use that frig so we could keep the door shut.
is unplugging the frig like resetting it?
thanks.
#12 Posted : Monday, March 26, 2012 3:16:20 PM(UTC)
Originally Posted by: rgill Go to Quoted Post
..is unplugging the frig like resetting it?...
Yes, it does.
rgill
#13 Posted : Tuesday, June 19, 2012 10:31:17 AM(UTC)
rgill
hi - well, frig worked well for about 3 months. Now, we have a freezer temp at 0 ti -2 and a frig temp that won't go below 48. During the day, 50 and then overnight to 48. We have unplugged it and when we did, i looked at the coils, but, they weren't dusty as we cleaned them 3 months ago.
the ice maker and water doesn't work, the temp is unstable as best. The machine is 7 years old. Is there anything else you can think of to do? i really don't want to invest any more in labor on a service call, but, also don't want to spend the $ on a new frig.
thanks!
#14 Posted : Tuesday, June 19, 2012 11:13:39 AM(UTC)
Does the fan inside the freezer work properly?
rgill
#15 Posted : Tuesday, June 19, 2012 11:18:00 AM(UTC)
rgill
how can i tell if the fan is working? Listening for it?
thank you.
#16 Posted : Tuesday, June 19, 2012 11:24:26 AM(UTC)
Make sure the compressor is on. Open the freezer door and listen to the fan. If you can hear it, check the air flow inside the freezer.
rgill
#17 Posted : Tuesday, June 19, 2012 11:46:34 AM(UTC)
rgill
the air is circulating and the fan sounds like its running
#18 Posted : Tuesday, June 19, 2012 12:37:26 PM(UTC)
Check the air flow in the fresh food compartment.
rgill
#19 Posted : Tuesday, June 19, 2012 12:41:20 PM(UTC)
rgill
other than the very narrow oblong space at the front of the frig, where would i check for air flow?
#20 Posted : Tuesday, June 19, 2012 1:16:08 PM(UTC)
Check out the attached file.
File Attachment(s):
Top mount PTS - ETS - Air flow.doc (202kb) downloaded 40 time(s).
Guest (4)
5 Pages<1234>»
