5 Pages«<345
rgill
#41 Posted : Monday, June 25, 2012 3:16:22 PM(UTC)
rgill
Gene - My husband installed the part yesterday AM and we've given it an entire day to work. Unfortunately, the frig temp isn't being brought down and the digital display isn't giving accurate reads. i know this b/c my stand alone frig thermometer is displaying a warmer temp. the freezer is also giving inaccurate reads.
what next??
thanks much,
Rebecca
#42 Posted : Monday, June 25, 2012 4:11:49 PM(UTC)
Hi Rebecca,
I would like to start over all tests. I need you to follow ALL my instructions and post answers on ALL my questions. Otherwise I would not be able to help you and you will have to call a certified refrigerator tech.
There is a fan inside the freezer. It should work at high speed (about 3000 rpm). You can reach it by removing the evaporator cover (#201 at the diagram) while the refrigerator is still running. At the same time you can see how the evaporator coils are covered with frost.
Please do it and post the results.
rgill
#43 Posted : Tuesday, June 26, 2012 3:55:42 PM(UTC)
rgill
This is Rebecca's husband. The fan is barely running and the coils are covered in frost as was most of the inside of the freezer. it appeared as if it wasn't a frost free freezer.
rgill
#44 Posted : Tuesday, June 26, 2012 4:12:04 PM(UTC)
rgill
One other piece of info. the fan is now running much faster than it was when i was disassembling the inside of the freezer with the door open. i have no way to tell if it is 3000 rpms
thank you.
rgill
#45 Posted : Wednesday, June 27, 2012 7:15:04 AM(UTC)
rgill
hi Gene - i appreciate all the help you've given us. This morning our freezer temp is -13 and the frig is finally at 37. The part #201 is still detached and the back that covers the coils is leaning against the back of the freezer. We were hoping to hear back from you before we reassembled everything.
Any suggestions or should we just wait and see if the temp remains at 37 in the frig? Is it a problem that the freezer is -13?
thanks very much,
Rebecca
rgill
#46 Posted : Wednesday, June 27, 2012 10:41:40 AM(UTC)
rgill
Gene - I'm wondering if you are getting any of our questions and or results we've posted.
Thanks,
Rebecca
#47 Posted : Wednesday, June 27, 2012 12:09:28 PM(UTC)
Hi Rebecca,
I'm just one of a few other volunteers on this forum. Unfortunately, I can not be here 24/7.
Quote:
...The fan is barely running and the coils are covered in frost as was most of the inside of the freezer. it appeared as if it wasn't a frost free freezer...
In such situation I would recommend to replace the evaporator fan motor and the main control board.
- The fan motor Part number: WR60X10228
- The main control board Part number: WR55X10942
Guest
#48 Posted : Tuesday, August 17, 2021 2:39:40 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Ge profile fridge french doors counter depth.The item is just under 6 years old,compressor went out.Anyone else with this problem. GE no help.Stuck.
5 Pages«<345
