lca2faraway
#1 Posted : Monday, March 26, 2012 8:11:44 AM(UTC)
lca2faraway
glass top range heating elements cycle on and off repeatedly but don't really get that hot. Is there a problem with the limit switch?
Simon / APP Team
#2 Posted : Monday, March 26, 2012 3:01:03 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please be more specific: Are all four elements acting up?
Thank you . Post the results.
lca2faraway
#3 Posted : Tuesday, March 27, 2012 7:56:51 AM(UTC)
lca2faraway
Yes all four elements are cycling. They begin to cycle almost imediately.
Simon / APP Team
#4 Posted : Tuesday, March 27, 2012 9:11:04 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check for 240v at the terminal block and tighten power cord contacts.
If the oven heating up good, then most likely you have all 4 burner switches go bad at the same time.
That is very untypical. Unless they went one by one.
I recommend you to replace one switch at the time and see if it will fix the problem.
You can return any unused parts even if they have been installed.
The left/rear and r/front infinite switch
Part number: AP3046996
The right/rear infinite switch Part number: AP3010400
The l/front infinite switch Part number: AP3030161
Her are the breakdown diagrams and Replacement parts for Whirlpool RS696PXGQ2 RANGE | AppliancePartsPros.com
Good luck. Post the results.
