3 Pages<123>
TMTaylor
#11 Posted : Tuesday, May 18, 2010 5:45:36 PM(UTC)
TMTaylor
same problem with my range and the bake doesn't work on the oven...sears says my model is not one of the ones that is being recalled..
even though it is having the same problem as the ones being recalled...makes sense,,,ha ha.. NO!:mad:
D64
#12 Posted : Saturday, October 30, 2010 8:12:30 AM(UTC)
D64
Our Kenmore Model 665-92012102 has failed us three times now. When using the oven it had an error code f3. The heating eliment in the oven would not turn off unless the stove is unplugged or the breaker is turned off. We were lucky to be at home when it happened.
manselmo
#13 Posted : Monday, March 26, 2012 7:05:06 AM(UTC)
manselmo
Same thing happened to me. Brand new Kenmore Elite electric top started popping and smoke came out of the control panel. I shut everything down, but it would not shout off. Finally, I had to go into the garage and find the breaker. How can anyone make something like this and not recall the product. They must know after they repair the top they will be liable in the future.
Marc
kmesse
#14 Posted : Monday, November 26, 2012 4:41:10 PM(UTC)
kmesse
Has there been a recall on this condition? Kenmore range, burner is blazing hot and stays on whatever the temp. If I turn the knob off and on a couple times, sometimes it'll turn off. What should I replace?
#15 Posted : Tuesday, November 27, 2012 2:45:41 PM(UTC)
I did not hear about such recalls but you can verify it with Sears.
What is the complete model number of the range?
kmesse
#16 Posted : Tuesday, November 27, 2012 5:21:09 PM(UTC)
kmesse
790.96119408 black
would it just be the switch for the burner? I don't hear the relay click when I turn it off like other switches.
Infinite switch they call it maybe?
#17 Posted : Tuesday, November 27, 2012 6:22:41 PM(UTC)
Most likely the problem is a bad infinite switch for this burner. There are three different switches used.
- The infinite switch for small element (6") Part number: 316436000
- The infinite switch for large element (9") Part number: 316436001
- The infinite switch for dual element Part number: 316238201
kmesse
#18 Posted : Saturday, December 1, 2012 3:48:48 AM(UTC)
kmesse
Done! Swapped large element sw. $12 part and 15 mins saved me a couple hundred from $ear$ Support. Thanks so much!
#19 Posted : Saturday, December 1, 2012 11:49:13 AM(UTC)
You are welcome. I'm glad you were able to fix it.
spacemanspiff68
#20 Posted : Saturday, June 22, 2013 3:27:59 PM(UTC)
spacemanspiff68
Similar problem but with Kennmore gas range. After the oven has been turned off it will turn back on and off and on by itself.
Called to see if this range was part of a Kennmore recall and it isn't.
Any ideas?
Guest (4)
3 Pages<123>
