How do you remove the automatic detengent, bleach, softener dispenser?
It is clogged and needs to be cleaned.
There is a lever all the way to the back of the dispenser on the left hand side that should let you remove the dispenser. push down and pull forward.
Originally Posted by: kanislatrans  There is a lever all the way to the back of the dispenser on the left hand side that should let you remove the dispenser. push down and pull forward. It worked!!! Thank you so much.
