shawhop
#1 Posted : 16 years ago
shawhop
Broiler doesnt come on.is the element usually the issue?
ApplianceJunk
#2 Posted : 16 years ago
ApplianceJunk
Yes chances are it just a bad broil element.
ApplianceJunk
#3 Posted : 16 years ago
ApplianceJunk
The way to tell for sure would be to use a volt/ohm meter to check it.
If you do not have a meter take a look at the wires plugged into the element as sometimes one will burn off.
If a wire is burnt off then repair the wire and try it before you order a new element.
Broiler doesnt work (Oven Repair (including Ranges and Cooktops))
by shawhop 16 years ago
