trpfn
#1 Posted : Wednesday, November 30, 2011 2:34:45 PM(UTC)
trpfn
kenmore 80 110.72982110 Won\'t drain or spin. Timer was at off. I tried spin only cycle and water level dropped but no spinning.
Eventually most of the water drained and I could get it to spin but not
drain any further. 1st thing I checked was lid switch. It was OK. Ohm test
switch and jumped wires. Not the switch. I removed the hoses to the pump and could not find any obstruction. This is an old kenmore 80 and I don\'t want to start replacing parts to find out which one is bad. Do you have any idea what the problem might be?
#2 Posted : Wednesday, November 30, 2011 3:42:32 PM(UTC)
Sounds like the problem is a bad water pump.
- The water pump Part number: AP3138954
trpfn
#3 Posted : Wednesday, November 30, 2011 4:25:33 PM(UTC)
trpfn
I am going to replace the, pump. You wouldn't happen to have instructions. If not I will wing it. Thank you.
2501329
#4 Posted : Friday, March 23, 2012 10:16:08 PM(UTC)
2501329
Water pump suspect. take it out and look inside for broken/worn down impeller blades.
