Attempted to do a load on quick wash cycle. Drum fills with with water but doesnt spin. Unit throws the OE code.
Groups: APP Team
Hello.
The OE code points to water overflow. Check the plastic pressure tube connection at the tub and water level sensor.
Post the results.
Everything looks good. I still can't get the motor to work. The drum will not spin under any function ( wash or test.)
Groups: APP Team
Hi.
I am afraid you have a bad control board. To get you the right part I need a serial number.
Thank you.
