robnpeg82
#1 Posted : 13 years ago
robnpeg82
the automatic dispenser seems to be clogged. a post mentioned placing the unit in service mode to run a purge cycle. how do I place the unit in service mode and start the purge cycle and then how do I return it to operation?
Joe / APP Team
#2 Posted : 13 years ago
Joe / APP Team
Robnpeg,
Here are the instructions for entering the service mode.
It is reccomended you run the purge cycle 3 times, that's going to take a while.
TO ENTER SERVICE MODE:
PRESS AND HOLD THE SELECT CYCLE BUTTON AND THEN PRESS THE HEATED DRY BUTTON SIMULTANEOUSLY FOR 3 SECONDS.
Then follow the purge detergent dispenser instructions below:
http://forum.appliancepartspros...pense-ge-profile-dw.html
Good Luck,
