Discuss
Problem with SmartDispense on GE Profile DW
 in
Dishwasher Repair
I didn't read the manual carefully enough and mixed two different types of detergent in my GE dishwasher. This
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Problem with SmartDispense on GE Profile DW
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-25-2008, 02:37 PM
danosgood danosgood is offline
Junior Member
danosgood is on a distinguished road
Default Problem with SmartDispense on GE Profile DW
Model Number: PDW8680N00SS   Brand: GE   Age: 1 - 5 years
I didn't read the manual carefully enough and mixed two different types of detergent in my GE dishwasher. This is the one that you can put a whole bottle of detergent into. The detergent gelled and gummed up the system. I've purchased a new pump and replacement looks pretty straight forward. I wanted to remove the resevoir to get it thouroughly cleaned, but can't seem to figure out how to do that. Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-25-2008, 02:42 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
First off, I doubt your motor is plugged, usually the nipple at the end of the reservoir plugs up. Also if you remove the dispenser, you need to replace the collar as it will leak once removed. There is a way to purge the system, and this may help, it usually does. Give me a minute to get you those instructions, if the purging fails to get it going again, you will need to purchase the bottle kit, I say kit because it has new seals and a strap wrench needed to remove the collar.
__________________
Who wants a chance to win $10,000 a week for the next 17 weeks? How about $250,000 if you have the most points after 17 weeks. The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 06-25-2008, 02:50 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Consumer Purge Cycle
The consumer must enter Service Mode to activate
the purge cycle. The purge cycle fi lls the dishwasher
for 57 seconds, then energizes the dispenser pump
(instead of the main motor) continuously to drain
the bulk dispenser tank .
The purge cycle deselects all other options and
runs for 65 minutes. The consumer should run the
purge cycle 3 times, filling the dispenser tank with
water for the second and third cycles. Total time is
approximately 3 hours.
Follow these steps carefully to have a successful
purge run.
For Front Mount Controls (PDW8900 series dishwashers)
For Top Mount Controls (PDW9700, PDW9900 series dishwashers)
For Front mount controls (PDW8600 series dishwashers, pay attention to step 3. Press added heat pad and cookware!!!!
1.
Make sure Pre-wash, Added Heat, and Heated
Dry LEDs are off.
2.
Press Heated Dry pad and Cookware pad
(down arrow pad on Top Mount Control models)
together for 3 seconds. All LEDs illuminate.
3.
Press Added Heat pad and Normal pad (up
together for 3 seconds. The Anti-bacterial LED
illuminates.
For PDW 8600 series Press added heat pad and cookware(up arrow pad on top mount control models)
4.
Press Start pad one time.
5.
Press Normal Wash pad and make sure Prewash,
Added Heat and Heated Dry LEDs are off.
6.
Press Start pad. Dishwasher will run a complete
cycle without the main motor running. Cycle is
complete when the clean light illuminates. This
should take approximately 60 minutes.
7.
Open door and wipe up the excess detergent
from the door and tub.
8.
Pour water on the door and tub where there is
detergent residue.
9.
Remove SmartDispenseTM cap and fill tank with
water. Replace cap.
10. Repeat steps 1 through 9 one time.
11. Repeat steps 1 through 6. When the Clean LED
illuminates, the system is purged and ready to
be refilled with the correct detergent.
– 18 –
__________________
  #4 (permalink)
Old 06-25-2008, 03:03 PM
Junior Member
Default
Thanks. I will try that this evening. I've run several cycles using clear water in the dispenser, but didn't know about the purge cycle.
  #5 (permalink)
Old 06-26-2008, 07:39 AM
Junior Member
Default
In the sequence you provided steps 1&2 went as described and all LEDs illuminated. At step 3, after pressing Added Heat and Normal for 3 seconds the Anti-Bacterial light did not come on, but a motor started running. It wasn't the dispenser motor though, it was under the DW. The directions you provided say they're for front-mount controls on a PDW8900 dw. Mine is a PDW8680 with front-mounted controls. Could there be a different sequence?
  #6 (permalink)
Old 06-26-2008, 09:05 AM
Junior Member
Default
Sorry if this posted twice. I'm not used to forums.
  #7 (permalink)
Old 06-26-2008, 09:33 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Those instructions are universal for all smartdispense dishwashers, straight from the Tech manual, let me look into it a bit more. It could be that in step 3 you did not push them together, I know if you push one just ahaed of the other it wont work.
__________________
  #8 (permalink)
Old 06-26-2008, 10:03 AM
Junior Member
Default
I went back and tried again - several times with the same results. I have the door closed. After step 2 all LEDs illuminate for about 2-3 seconds, and then go out. I have tried pressing "Normal Wash" and "Added Heat" both while the LEDs are lit (nothing happens), or after they've gone out, at which point the motor starts up. I can't tell what is happening while the motor is running. It definitely is not filling the dw. I let the motor run as long a 3 minutes before restting it.
  #9 (permalink)
Old 06-26-2008, 10:29 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Did you continue the instructions after step 3 or did you stop?
__________________
  #10 (permalink)
Old 06-26-2008, 10:48 AM
Junior Member
Default
I had been stopping at that point since the Antibacterial LED never illuminated. If I continue on it simply runs a normal wash cycle.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer problem in LARGE load setting- timer problem? jagtianis Washer Repair 9 08-04-2008 02:49 AM
GE Profile Stove Top Burner Problem martys Oven Repair (including Ranges and Cooktops) 6 07-23-2008 06:39 PM
Ge profile fill problem Danfros Dishwasher Repair 2 04-15-2008 05:59 AM
Thanksgiving Oven Problem.....its still a Problem! rbmattila Oven Repair (including Ranges and Cooktops) 1 03-03-2008 09:05 AM
Ge Profile XL44 Burner Problem djdresden Oven Repair (including Ranges and Cooktops) 0 02-23-2008 11:56 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
