John Osgood
#1 Posted : Sunday, March 18, 2012 10:25:52 AM(UTC)
John Osgood
How much of the machine do I have to dismantal to get the belt over the drum.Need dyagram
JW Webster
#2 Posted : Tuesday, March 20, 2012 1:28:33 PM(UTC)
JW Webster
You must first remove the top. Then remove the splash plate and the controls. They have quick connects. Remove the rear hatch. Get the front panel off and remove the drum. Clear out the lint and check the glides and the rear bearing. It seems tough but it is not that difficult.
#3 Posted : Tuesday, March 20, 2012 3:26:17 PM(UTC)
Hi John,
You can use the instructions from the file attached to the reply. You have to read the first three pages only.
If the belt broke, just replace it.
If the belt fell off, inspect the idler pulley.
- The belt Part number: AP4565702
- The idler arm Part number: AP2132056
File Attachment(s):
SG1000 dryer belt replacement (Dryer Repair)
by Guest 6/28/2021 3:29:53 PM(UTC)
by lesteree 8/1/2011 5:43:09 PM(UTC)
Frigidaire electric dryer belt replacement (Dryer Repair)
by award 6/21/2010 11:14:23 AM(UTC)
by treedogg 10/8/2009 1:10:32 PM(UTC)
Roper Dryer belt Replacement (Dryer Repair)
by Dubya_tee 9/29/2009 2:13:46 PM(UTC)
Maytag dryer belt replacement (Dryer Repair)
by benb 9/15/2009 12:37:33 PM(UTC)
need photos of ge dryer belt replacement (Dishwasher Repair)
by steeler0ne 8/20/2009 8:49:20 AM(UTC)
Dryer belt replacement (Dryer Repair)
by Donald Marden 7/10/2009 2:55:33 AM(UTC)
by twoziggie 6/11/2009 5:18:32 AM(UTC)
by bwilliams 1/4/2009 9:18:53 AM(UTC)
by jbmamaww 11/28/2008 12:28:16 PM(UTC)
Admiral Gas Dryer Belt Replacement (Dryer Repair)
by STEMARHOL 11/8/2008 1:35:17 PM(UTC)
Maytag Dryer Belt Replacement (Dryer Repair)
by Muzzy90G 9/1/2008 6:49:08 AM(UTC)
by lordemmett 5/23/2008 11:07:20 AM(UTC)
by kgnjay 3/4/2008 9:54:25 AM(UTC)
