I tried your solution but unfortunately it did not work for me. I unplug the 2 ribbon wires, unplug all other wires (blue, red, brown, black, yellow, orange), replug, tried to reset the broil temperature to 450 but again everything froze there and I got the infamous F13 message.
Any ideas ?
I registered just so I could thank you! It will probably take me longer overall to thank you than it did to fix my stove. It works on a frigidaire model #ples389acc. A million thank yous, as you have saved me some money I will definitely need for Christmas.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
This reply is 11 years later, but pulling the small connectors from the control board and plugging them back (a couple of times) also fixed the F13 broiler ssue. I couldn't remove the larger ones (didn't want to break anything), but one of the small ones fixed the problem. Thanks 11 years later!
