korean1
#1 Posted : Monday, March 12, 2012 6:02:17 AM(UTC)
korean1
Not making ice. Ran a cleaning cycle with approved cleaner. Maker sounds like a grunting noise. I have to turn it off then press clean cycle but then turn it back on to get it to start back up. Now the water is not shutting off and causing it to overrun the resivour. After the cleaning solution cycle I did last week it ran fine.
#2 Posted : Monday, March 12, 2012 8:49:36 AM(UTC)
How cold on touch is the evaporator?
Clean the condenser and make sure the fan motor works fine.
Post the results.
Here are the breakdown diagrams and Replacement parts for Whirlpool KUIS18NNJW8 ICE CUBE MAKER | AppliancePartsPros.com
korean1
#3 Posted : Monday, March 12, 2012 9:08:14 AM(UTC)
korean1
Gene,
It's currently making ice. But thats what's curious. On occassion it stops cycling water then starts that grunting noise. With it making ice now would this eliminate the evap showing bad. is there something else not telling it to cycle water to the evap?
#4 Posted : Monday, March 12, 2012 10:11:25 AM(UTC)
You can run the self diagnostic as described in the attached tech sheet.
File Attachment(s):
undercounter icemaker (Refrigerator & Freezer Repair)
by foleymech 6/1/2010 5:03:22 PM(UTC)
Kitchenaid Undercounter Icemaker (Refrigerator & Freezer Repair)
by DAMON ROY 5/22/2009 2:36:42 AM(UTC)
Undercounter icemaker won't make ice (Refrigerator & Freezer Repair)
by Terry Turner 10/9/2007 10:17:38 AM(UTC)
