When I unplug the power from the wall to the unit, few minutes later I plug the power back but it is dead on control panel. It is working before I unplug it. I try to reset it because the Bake function does't working right like before. Now, the Burner is OK and the Oven light is working fine except control panel is dead. No timer, Clock, Bake... So, How can I fix this problem. Should I need to change the control panel?? Tell me how. Thank you.
David
Your model number does not come up, also it does not look correct. Maytag numbers are usually 3 letters then a few numbers and then more letters. Please check it. Model Number Locator |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Your model number does not come up, also it does not look correct. Maytag numbers are usually 3 letters then a few numbers and then more letters. Please check it. Model Number Locator Hi Denman, Thank you for your help, I know what i need to fix my problem. Thanks again. David
