gerald rother
#1 Posted : 16 years ago
gerald rother
The motor on my sons whirlpool dryer did not run at all so I replaced it with a new one. Now the new one only run about 20 sec. and then everything shuts down (no heat and motor stops). I have checked all the thermostates on the back and think that they are ok.
Could I have received a bad motor (faulty overload) or perhaps the main contoller has issues?
Thanks,
Jerry
kayakcrzy
#2 Posted : 16 years ago
kayakcrzy
We would really need a model number of the dryer to know for sure. Open the door of the dryer, and it should be where the dryer door closes on the dryer. Tom ApplianceEducator.com
gerald rother
#3 Posted : 16 years ago
gerald rother
whirlpool Mod. #WED5100SQO
kayakcrzy
#4 Posted : 16 years ago
kayakcrzy
Jerry it could be the door switch, or it could be the timer. I would jump out the door switch and see if it runs, or you could check it for continuity if you have a ohm meter. There is also a thermal fuse, that could have gone out. It is in the back of the dryer, and is about an inch and a half long, by a half inch wide. Pull the wires off of it, and ohm it out. Tom ApplianceEducator.com
Jerry (Washer Repair)
by jkdryer 10 years ago
jerry (Oven Repair (including Ranges and Cooktops))
by jerry harp 12 years ago
jerry6149 (Washer Repair)
by jerry6149 12 years ago
jerryas121 (Refrigerator & Freezer Repair)
by jerryas121 14 years ago
how can I jerry rig a hook up? (Washer Repair)
by handyman Glenn 15 years ago
