gerald rother
#1 Posted : Sunday, March 8, 2009 7:32:40 AM(UTC)
gerald rother
The motor on my sons whirlpool dryer did not run at all so I replaced it with a new one. Now the new one only run about 20 sec. and then everything shuts down (no heat and motor stops). I have checked all the thermostates on the back and think that they are ok.
Could I have received a bad motor (faulty overload) or perhaps the main contoller has issues?
Thanks,
Jerry
kayakcrzy
#2 Posted : Sunday, March 8, 2009 4:03:23 PM(UTC)
kayakcrzy
We would really need a model number of the dryer to know for sure. Open the door of the dryer, and it should be where the dryer door closes on the dryer. Tom ApplianceEducator.com
gerald rother
#3 Posted : Sunday, March 8, 2009 7:01:15 PM(UTC)
gerald rother
whirlpool Mod. #WED5100SQO
kayakcrzy
#4 Posted : Monday, March 9, 2009 3:51:11 AM(UTC)
kayakcrzy
Jerry it could be the door switch, or it could be the timer. I would jump out the door switch and see if it runs, or you could check it for continuity if you have a ohm meter. There is also a thermal fuse, that could have gone out. It is in the back of the dryer, and is about an inch and a half long, by a half inch wide. Pull the wires off of it, and ohm it out. Tom ApplianceEducator.com
Jerry (Washer Repair)
by jkdryer 6/28/2015 8:02:40 AM(UTC)
jerry (Oven Repair (including Ranges and Cooktops))
by jerry harp 7/16/2013 8:26:02 PM(UTC)
jerry6149 (Washer Repair)
by jerry6149 4/3/2013 1:57:09 PM(UTC)
jerryas121 (Refrigerator & Freezer Repair)
by jerryas121 10/5/2010 11:27:08 AM(UTC)
how can I jerry rig a hook up? (Washer Repair)
by handyman Glenn 8/18/2010 3:14:57 PM(UTC)
