gnewhart
#1 Posted : Friday, March 6, 2009 5:25:23 AM(UTC)
gnewhart
Over the range microwave, when I open the door it sags 1/4 inch. When I close it just as it closes it moves up and is then flush when fully closed.
Is it ok like this?
If it needs to be fixed any suggestions?:confused:
Thanks, Glenn
#2 Posted : Friday, March 6, 2009 7:37:16 PM(UTC)
Glenn,
Remove the bottom panel and the top grill and check both door hinges.
Here are the break down diagrams and the parts list for the Maytag microwave Model MMV4184AAB
gnewhart
#3 Posted : Saturday, March 7, 2009 5:35:59 AM(UTC)
gnewhart
Gene, thanks for the info and diagram.
1.How will I know which hinge is bad?
2. This looks pretty complicated for a beginner homeowner like me. Will it hurt to leave the door as is?
Thank you for your help and patience! Glenn
#4 Posted : Saturday, March 7, 2009 6:39:07 PM(UTC)
Originally Posted by: gnewhart Go to Quoted Post
...it moves up and is then flush when fully closed...
Glenn,
It can cause a radiation leakage. It has to be fixed. If you can not do it yourself then hire a pro or replace the microwave.
gnewhart
#5 Posted : Sunday, March 8, 2009 11:23:00 AM(UTC)
gnewhart
Thanks, that is what I needed to know. I live in Florida. Any idea how much a repair like this would cost?
#6 Posted : Sunday, March 8, 2009 5:36:13 PM(UTC)
It is very hard to predict. The price depends on a parts involved.
