Tryingtofix
#1 Posted : Sunday, March 8, 2009 5:13:12 PM(UTC)
Tryingtofix
I have a Maytag Performa gas dryer with above model number and serial number 12854781UW that requires 3+ cycles to dry clothes. I have cleaned the vent and there is sufficient airflow through output vent. It feels as though the air feels cool or mildly warm if that. I have turned the dryer on while the door was still open to see if in fact the drum is rotating which is the case. I have checked the gas switch valve to make sure the valve is in the on direction. I am currently debating whether if it is worth it to repair this one or if I should just purchase a new dryer . Please help any advice is greatly appreciated. Thanks:)
Tryingtofix
#2 Posted : Sunday, March 8, 2009 6:17:26 PM(UTC)
Tryingtofix
Just checked my dryer on a whim and it does get warm but not as hot as to dry the clothes in 1 cycle. The dryer used to do this on occasion before it did not provide enough heat. Could it be a build up of lint blocking the igniter or something?
#3 Posted : Sunday, March 8, 2009 6:25:49 PM(UTC)
Take the dryer apart and clean the air ducts and the blower housing. Replace the gas valve coils.
- The part number for the coil kit is AP2150379
Here are the break down diagrams and the parts list for the Maytag dryer Model PYG2000AWW
Tryingtofix
#4 Posted : Monday, March 9, 2009 9:07:06 PM(UTC)
Tryingtofix
Thanks Gene! I'll give it try. I'll let you know the results.
Tryingtofix
#5 Posted : Friday, March 13, 2009 6:13:25 PM(UTC)
Tryingtofix
Gene,
I received the part today and was wondering how to gain access into the dryer to replace the part. Thanks!
Tryingtofix
#6 Posted : Friday, March 13, 2009 8:03:36 PM(UTC)
Tryingtofix
Was able to find out how to access the part using another forum
Maytag performa dryer-How does the front panel come off?? - Self Help Forums
I replaced the coils and the dryer works just fine:D
