2 Pages12>
jd1md1
#1 Posted : Monday, February 27, 2012 6:20:52 AM(UTC)
jd1md1
while in wash and rinse cycle machine makes a loud noise, sounds like raking gravel.
#2 Posted : Monday, February 27, 2012 6:04:57 PM(UTC)
Sounds like the problem is a bad bearing. The fix is to replace the outer tub assembly.
- The outer tub assembly Part number: AP4567773
jd1md1
#3 Posted : Wednesday, February 29, 2012 5:47:38 AM(UTC)
jd1md1
Hi Gene, Thanks for reply. Does the tub only spin in wash and rinse cycle? Can only the bearing be replaced? How difficult is it to replace the outer tub? Should these washers without a agetator make more noise than usual?
Bob
#4 Posted : Wednesday, February 29, 2012 1:42:18 PM(UTC)
This bearing is a part of the outer tub and can not be replaced separately. The outer tub does not spin. The transmission shaft goes through the central seal/bearing. This job requires complete disassemble of the washer.
jd1md1
#5 Posted : Monday, March 5, 2012 8:13:38 AM(UTC)
jd1md1
Gene,
Seems like problem is in gear box.
How does wash plate come off?
#6 Posted : Monday, March 5, 2012 3:05:37 PM(UTC)
Remove the cap and the screw (#1 & #2 on the diagram).
#7 Posted : Monday, March 5, 2012 4:07:10 PM(UTC)
I found the instructions for you. They are attached to the reply.
File Attachment(s):
Removing the top.doc (371kb) downloaded 15 time(s).
Removing the tub ring.doc (313kb) downloaded 11 time(s).
Removing the impeller and basket.doc (145kb) downloaded 11 time(s).
Removing the gearcase.doc (126kb) downloaded 10 time(s).
jd1md1
#8 Posted : Tuesday, March 6, 2012 7:48:06 AM(UTC)
jd1md1
Gene,
I figured that out. Purchased outer tub assembly to fix bad bearing as advised. I do not see any bearing, just seal like on old one. Should there be some type of bearing?
jd1md1
#9 Posted : Wednesday, March 7, 2012 11:41:55 AM(UTC)
jd1md1
Gene,
Any reply to no bearing in outer tub?
Markram
#10 Posted : Wednesday, March 7, 2012 1:40:34 PM(UTC)
Markram
They make bearing replacement kits, and I have replaced several bearings already. I am a Sears Repair Tech, and am unsure if the kit is available online... it should be. I can look in my van and include the part number. Although I would not recommend this task for anyone that lacks experience with taking things apart.
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
2 Pages12>
