3 Pages<123
Joe / APP Team
#21 Posted : Tuesday, February 28, 2012 5:24:29 AM(UTC)
Joe / APP Team
Originally Posted by: jojonychome Go to Quoted Post
furious right now took the whole machine apart and replaced the rotor and the machine is still bouncing from side to side and up and down i am still getting the f1 code on the machine....i thought this was on recall for that problem
JoJo,
If you've done all the reccomended checks , repairs and lubrication, there's not a lot left to check.
Make sure the washer is level (in both directions)and the feet are locked and washer is as close the the floor as possible. Make sure there is no vibration or movement in the floor or flooring. But I thought you had done those checks, first.
I don't remember a "recall" for F1 or F51 codes, or vibration issue, There were quite a few technical updates, and we have already coverred all of those. You may want to contact the manufacturer and varify the recal, or see if they can assist you.
Guest (6)
wildride (Washer Repair)
by jojonychome 4/21/2011 9:54:32 AM(UTC)
3 Pages<123
