I have the frontload Frigidaire Affinity dryer and it will start and 10 seconds later it shuts off and the lights start blinking. If I hit the cancel button it will not turn off. The inside light is on. I have to unplug it to turn it off. Don't know what to do - hope someone knows the answer. :confused:
What is the complete model number of the dryer?
Hi Gene - it is a Frigidaire AGQ7000EG Affinity. Hope this helps - I will be awaiting your reply.
Thanks, Shannon
