smuller
#1 Posted : Monday, February 27, 2012 10:31:51 AM(UTC)
smuller
I have the frontload Frigidaire Affinity dryer and it will start and 10 seconds later it shuts off and the lights start blinking. If I hit the cancel button it will not turn off. The inside light is on. I have to unplug it to turn it off. Don't know what to do - hope someone knows the answer. :confused:
#2 Posted : Monday, February 27, 2012 2:06:17 PM(UTC)
What is the complete model number of the dryer?
smuller
#3 Posted : Tuesday, February 28, 2012 12:15:15 PM(UTC)
smuller
Hi Gene - it is a Frigidaire AGQ7000EG Affinity. Hope this helps - I will be awaiting your reply.
Thanks, Shannon
#4 Posted : Tuesday, February 28, 2012 2:56:55 PM(UTC)
Hi Shannon,
Run the dryer in the Field Test mode as instructed in the Tech Sheet and post the results.
Here are the breakdown diagrams and Replacement parts for Frigidaire AGQ7000EG0 Frigidaire/dryer | AppliancePartsPros.com
