Hershel Butler
#1 Posted : 13 years ago
Hershel Butler
Washer will ni go into final spin. Ran the diagnosis and got a E43 code. The door lock wax motor looked burned and showed 500 ohms so replaced it. Still getting a E43 code any ideas before I replace the control board?
sidfink43
#2 Posted : 13 years ago
sidfink43
I am not getting your model number to come up, but assuming this is a front load Frigidaire I would start by replacing the motor/speed control board. That is more like a source of a spin problem than the main control unit.
Hershel Butler
#3 Posted : 13 years ago
Hershel Butler
The model is LTF2940ES3 I replaced the main control board with the same code E43 I am not finding a motor control board and ready to take a hammer to the thing
sidfink43
#4 Posted : 13 years ago
sidfink43
Okay, here is the part
Part number: AP3891780
but first check the drain pump and hoses for any obstruction and the door lock and wiring for any problem. The tech notes inside the lower service panel will show you how to do some testing.
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 10 years ago
Frigidaire washer wont spin (Washer Repair)
by MsNana2U 15 years ago
Frigidaire washer wont spin! (Washer Repair)
by Jim McFarland 17 years ago
