Electric Dryer operates but does not heat up. I noticed this after a repairman shorted the hot wire from the house fuse box that goes to the dryer. the electrical short, shut the whole house down, we had to reset the house breaker. My Question is does the dryer have a protective fuse that might have blown? need help
Reset the breaker for the DRYER!!!!!!!!!
Originally Posted by: Drags1998  Reset the breaker for the DRYER!!!!!!!!! Electric Dryer operates but does not heat up. I noticed this after a repairman shorted the hot wire from the house fuse box that goes to the dryer. the electrical short, shut the whole house down, we had to reset the house breaker. My Question is does the dryer have a protective fuse that might have blown? need help I already reset the house main breaker and the breaker that goes to the dryer. both breakers are working fine.
Electric Dryer operates but does not heat up. I noticed this after a repairman shorted the hot wire from the house fuse box that goes to the dryer. the electrical short, shut the whole house down, we had to reset the house breaker. My Question is does the dryer have a protective fuse that might have blown? need help I already reset the house main breaker and the breaker that goes to the dryer. both breakers are working fine. Dryer still does not work
To answer your question, NO, it does not have a fuse. I'm a little confused, if the REPAIR MAN shorted it out, Why has HE not repaired the problem???? I would recommend finding a NEW REPAIR MAN!!!!!
