Mr.sockerskillz
#1 Posted : Monday, February 20, 2012 7:44:07 AM(UTC)
Mr.sockerskillz
Please help!!!!!!! my maytag refrig is freezing the coils up.... i already replaced the defrost t-stat but its still freezing... i turn the refrige off then on then off then on to activate the defrost manually and it kicks on to defrost!!! i guess my question is this.... am i bypassing the defrost timer when i force defrost by shutting off then on or because it comes on is my deforst timer good? OR MAYBE MY DEFROST THERMOSTAT IS BAD AGAIN???????? PLS HELP N GOD BLESS
#2 Posted : Monday, February 20, 2012 3:32:22 PM(UTC)
Activate defrost and see if it defrosts the coils completely.
Mr.sockerskillz
#3 Posted : Monday, February 20, 2012 4:05:49 PM(UTC)
Mr.sockerskillz
Yes boss it defrost completly
#4 Posted : Tuesday, February 21, 2012 12:22:48 AM(UTC)
I would replace the adaptive defrost board AP4078743 even though it seems to work, it may not be processing input data sufficiently to initiate defrost.
