kauf974
#1 Posted : 13 years ago
kauf974
I have a GE Profile Spaemaker microwave model number JVM1660WB01. This is a over the range model with a vent fan built in.
Is the magnetron replaceable? I researched the magnetron and it appears several companies will not sell you the part unless their technician comes out and does the work.
The other day smelled a burning smell. I partially removed some of the pannels and could see the connector on the magnetron is black. What parts would need to be replaced on this microwave and how do I get all the way to it to repair?
I've attached a couple of photo's of the connector and the unit.
Any thoughts on the parts I would need?
kauf974 attached the following image(s):
kauf974
#2 Posted : 13 years ago
kauf974
kauf974
#3 Posted : 13 years ago
kauf974
Should I repair or replace this unit?
